I have the manual and the tools for the tappet check but I don't have the ability to predict when one of the cover mounts is about to fail!
Let me explain...
I looked over the manual for the 14500 mile maintenance and since I've done all the maintenance on my Gold Wing I was determined to do it on my Burgman as well, except the stuff I don't have but need special tools for. Way back with my first bike, a Harley, I had to first rebuild the engine before I could ride. So having that experience under my belt I know it is only a matter of having the right tools and then I can do it. Well, I launched into the tappet check and all were within tolerance as everyone else has found. Putting the cylinder head cover back on was when it went bad for me. Turns out that the threads in one of the mounts for the cover were on the verge of failure. No I didn't tighten anything too much. I have a torque wrench and use it. All 4 bolts threaded just fine initially. 3 bolts were able just start to seat, as I tightened each one just a little to keep it even all around. But the 4th bolt, lower right, barely started to seat and then went all loose again. As I said, I did not over torque, I did not even get close. I am now looking for a cam shaft holder, Exhaust side, as in the lower one, since that is what the bolts fasten to. Fortunately the head is OK. I know my dealer doesn't have this part in stock so I will have to order one from them. My dealer is one who would charge the $500-$600 for this maintenance interval so even buying this extra part I will still be way ahead... I hope. Has anyone had to replace one of these?
I am thinking that the threads in the mount were about to fail anyway and just happened to when I was reassembling. Better when the bike is apart for maintenance anyway than when on the road. But now I am without my main transportation until I get the part. AAAAHHHH! :angryfire:
Other than the very first maintenance, I have performed all maintenance myself without problem. I usually let the dealer do the first maintenance on any bike I buy just to be sure everything starts out done right. There is one more body plastic part that is supposed to be removed than what the picture shows above. That is the foot board piece that wraps over and in front of the saddle. I did remove all the plastic called for just because I wanted to have it all open to do some other things. Now I have more time to do some more things while it's apart.
