1st DIY oil change - observations and questions
1 reading
3.9K views 11 replies 10 participants last post by  IronRanger
#1 ·
I just did my first do-it-yourself oil change for my new 2006 Burgman 400.
It has 130 miles on it. I had read somewhere on a motorcycle engine break-in site that the majority of your wear-in will occur in about the first 75 or 100 miles. So changing the engine oil should be done soon after that.
Worst case - I've wasted $15 in parts and 35 minutes of my time.
Best case - I've saved my engine from needless wear by getting the break-in metal shavings out sooner rather than later.
I followed the instructions in the ever-so-helpful PDF (or is it a Word doc?) from Jason Somebody often mentioned on this forum, as well as comparing the instructions with what my service manual says.
Some things I found helpful:
1. The oil drain plug requires a 17mm wrench to remove
2. The oil filter cover bolts are 8mm heads
3. Warm the engine up, then wait a bit until your engine has cooled a bit -- you don't want to burn your fingers on the exhaust when you remove the dipstick cap, or burn your fingers on the hot oil when you remove the drain plug.
The oil looked sort of new (clear) but upon closer inspection it was completely littered with little metal particles and flakes, exactly what I was hoping to see after the first hundred or so miles -- hopefully a majority of the little harmful metal flakes from initial wear and tear on the engine during the break-in period. I wonder how much damage they would have done if left in there until the first service at 600.
Refilling the oil took exactly 1900 ml, just as outlined in the PDF, for the dipstick to measure as full (below). The oil goes in VERY slowly... Take your time, it's like pouring thick maple syrup.
Otherwise it's exactly as outlined in the PDF. One thing to note: When you remove the oil filter cover, you will invariably get some escaping engine oil dripping onto the exhaust pipe, when you refill with new oil and start it up and let it run for a few minutes (as outlined in the service manual) it will burn off -- you will see smoke -- don't be alarmed. It will burn away and evaporate and leave no traces.
DO check the oil level after you've warmed up the engine, with the scooter off the center and side-stands, hold it upright with the emergency brake on and check with the dipstick unscrewed, cleaned off, and re-inserted but not screwed back on.
What I need help with is this:
There didn't seem to be an o-ring or other type of washer on the oil drain plug. There does *seem* to be some sort of built-in metal washer-type thing connected to the thread-side of the drain plug head, but it was not removable.
Did I miss something? IS there an engine oil drain plug washer to replace? Do you replace the drain plug every time if the engine oil drain plug washer is 'built in' to the drain plug? The service manual doesn't mention one, but if you check the parts fiche for the B400 it shows that there is one.
I'm going to keep my eye on it for the next couple of days to ensure that I snugged everything up appropriately. I do not have torque wrench but noted how tight each bolt felt when I removed it, and approximated it when I tightened everything up. Having changed my car's oil before, I'm familiar with the dangers of over-tightening the drain plug.
Thanks in advance for any assistance with my question about the presence (or absence?) of an engine oil drain plug washer/gasket.
#3 ·
Absolutely, I'm in no way doing trying to avoid anything for the 600 mile service, just trying to get out the bits of metal shavings ahead of time. I fully expect them to do an oil/filter change at the big 600 mile service and do everything regardless of this initial oil and filter change.
#5 ·
oil change
I did the same thing. Changed the oil at 170 mi just to be safe. I did my own 600 mile service @ 700 miles. Went fine, took 3 hours to check the valves, but the directions and pictures in the forum helped a lot.
Good luck, I just finished the 1000 mile break-in, so my Burgy and I are in full flight.
#6 ·
Nake,
I commend you on doing your oil change early (for all the reasons you listed)! :D
$15 is a small investment into the length of life for your 400 and now you know how easy it is and next change will only take you half the time! :D
#8 ·
Good job on the early oil change. Recycle the oil back to your lawn mower, or an older engine that is "well seasoned" anyway. The oil is still good, just has some flakes in it.
#9 ·
Don't know what mine took in ml, but I found that the capacity is exactly 2.1 Quarts, which is probably 1900ml, or close there.
If there is any washer on the drain plug, I didn't find one, either. Seems to work OK without one, so I doubt if one is required.
2006 AN400, a little over 2000 miles on it now. :) -Dave
#10 ·
Changed oil at 80 miles and again at 300 miles, didn't replace filter either time. I figured that if the filter picked up metal particles they would stay there and if not the oil changes would get rid of them.
Dealer did oil and filter change at the 600 mile inspection, am at 800+ miles now.
#11 ·
Next time, cut up a large tide jug or water jug, and make a piece about 2x4, and wedge it between the exhaust pipe and engine block. No oil spill! :wink:
#12 ·
I always change early, then again at the recommended service. Never hurts to get the initial filings out of the engine, instead of churning them around for 600 miles, and not all the oil passes through the filter before heading into the engine. On most bikes, a fair amount climbs the cam chain and is slung around the engine, metal grindings and all.
On the 400, I now throw an aluminum foil tent (with the edges curled up) over the exhaust pipe where it passes under the filter cap to protect the pipe. I did stain ours, plus, I don't like the smell of burning oil, and it sticks with the bike for a while.
