Tire pressure
1 reading
1.8K views 11 replies 8 participants last post by  Rubble
#1 ·
I posted the following on majestyusa.com and pasted it here since it applies to this forum also. Any comments is welcome.
I just check my pressure and the dealer delivered to me quite a few pounds under what Yamaha suggest for tire pressure. I thought they were suppose to check all that stuff before that gave the customer the bike.
No wonder for the last 135 miles I felt the bumps so much more.
I just inflated them to Yamaha recommended specs in the garage and wonder who follows what Yamaha suggests?
For my sportbike I run it well below what Kawasaki says since its well known to bikers running stock psi will lead to a serious accident. I am using 33/35 on the bike while Kawa suggests 39/42 which is insanity.
Since I am very new to the scooter world how safe is stock which is 29/36? Its been raining too much for me to test it out.
_________________
#2 ·
There has been some discussion on underinflated tires from the dealers, it's far too common than it should be. It's not just a Yamaha trait either, lots of Burgmans have been sent out lacking air.
Judging from what I've read around here, most people run factory recommended pressures.
Can you please elaborate on the tire pressures for sport bikes comment. I've never owned a sport bike but take great interest in them and have never heard that before.
#4 ·
From what I hear, and take it with a grain of salt, the recommend pressure for motorcycle and maxiscooter tires is usually given with an eye both at safety under normal conditions and good tire wear. The safety factor assumes you obey the speed limit, accelerate moderately, and most importantly don't ride turns hard.
For me on my Burgman 650 I run at suggested pressure and it seems right for good control and comfort.
NHTSA Link: Motorcycle Tire Safety Tips
#8 ·
I run mine at the recommended two up pressure. 33/41
The back tire I let go sometimes until it's down a few pounds, (it's hard to get in there anyway), but the front tire needs 33, or else I find the steering gets a little mushy feeling at slow handling speeds.
#9 ·
It's based on the idea that racers run lower pressures - but for them it's to build up heat quickly in their tyres for short races - assuming it's a race using street tyres.
It's not a good idea for street bikes in general, more an urban myth for boy racers.
Check the tyre manufacturers web sites rather than believe bike makers...
#10 ·
Not sure if it's the same for motorcycle tires, but I read an article in today's paper by one of the local car guru's, and he said that the pressure stamped into a tire is the maximum safe pressure to run the tire at, and that the manufacturer determines the pressure that is best for the vehicle based on the size and profile of the tires that are designated for it.
Like I said, not sure if that also applies to motorcycles.
#11 ·
Yeah, the pressure on the side of the tyre is a maximum, not a recommendation...
I had a full post typed up and lost it...sorry. Basically I'd trust the tyre maker over the bike maker because they are more focused on the tyre's handling/wear where the bike maker might be happy to compromise in the name of a soft ride (for instance).
In any case the bike makers recommendations become mute if you fit anything but the OEM tyre.
#12 ·
I found This Article that touches on lower pressure for street riders.
