Low oil
1.6K views 7 replies 8 participants last post by  excaliber
#1 ·
I bought a used 2006 Burgman 650 from a private owner. It has 4444 miles on the odometer. The day after I bought it I checked the level of the engine oil. Much to my surprise, it was below the "add" mark - yikes! I rode the Burgie home the day before - about 140 miles. The oil pressure light never came on, but now I am concerned about how much oil the engine had. I have since changed the oil and filter. It seems as though the site glass doesn't begin to show oil until about quart # 3. So I am hoping my lovely Burgie wasn't dangerously low on oil. I subsequently contacted the seller who bought it with 2500 miles on the clock. It had been serviced by the dealer then. He rode it about 1800 miles and had not changed the oil - and apparently hadn't checked it either.
So....I hope everything is OK. Other than changing the oil/filter AND closely watching the oil level....does anyone have any other advice?
Thanks!
#2 ·
Usually the "Oil Level" sign on the LCD screen will come on at the first hint of low oil. Without that, I'd say you are probably fine. The oil level you see is also highly dependent on HOW you check the oil. Put it on the centerstand, run it for 3 min, wait 3 min, then check it. That's the Suzuki standardized method.
#3 ·
Finks, if the oil level lite doesn't come on, you've got no worries. manufacturersm always figure in a bit extra sump quantity, for just such a situation as yours, as they KNOW some users will be neglectful of oil level, and want to give the engine ample supply.
further, the only time to worry about low oil, is if you can hear connecting rod knock, because connecting rods have about the highest load in teh engine, and are usually the first to poop the futon when the oil supply goes away.
as long as it doens't sound like there's someone inside the engine banging on the crackcase with a hammer, loudly, in time with the revs, ITS ALL GOOD ;-)
#5 ·
I believe it is an "oil pressure" warning light, not an "oil level" light.
I've come to the odd conclusion that the best way to check oil is to do an oil change. Whether it's a sight glass or there were a dip stick there, it's very dependent on method ( as stated above ).
#8 ·
Sheeshhh, no worries mate, ride on! It's fairly common for the oil to get a little low before the next oil change comes around. By the way, inbetween oil changes I unscrew the overfill plug on the trans and see if any excess oil drains out. A little bit usually does, I guess in my case thats where at least some of the engine oil is going.
