Blew a fuse yesterday!
Checked my tires and they were low a few pounds each.
Put the burg on the center stand and started the engine.
Got the cages air pump out and plugged it into the charger plug in the burgs glove box.
Blew up front tire, started on the rear tire and the fuse blew.
Grabbed the manual, located the "power outlet" fuse location, got down on one knee with the sun shining in my face and tried to see how to get the fuse out. Hard to see anything.
Found a red 10 amp fuse, pushed and shove it up and out, and found it was fine. Tested fine, looked fine.
Fiddled around until I figured out that the fuse I really wanted to get out was inside a white container with a press to release clip/cap thingy on it.
Found the blown fuse, replaced it, and realized as I was doing it that the first fuse I popped out was just a spare in a rubber holder on the side of the white fuse holder.
The Zuke actually anticipated that fuse blowing. Hmmm.
Guess I'll have to find another way to pump up the tires.
In the end, I used my hand pump for my bicycle tires, worked OK.
Even has a trustworthy guage on it.
As an excuse for another ride on the burg, drove over to Canadian Tire store and bought some more 10 amps and one 40 amp fuse.
There are two 40 amp main fuses on the 650 burg.
Now I'm ready!
If I never need them, I'm only out a few dollars, but if I do...... 8)
Now I'm ready!
