I wanted to change out the engine and gear oil before it got to cold here in Indiana. So after a warm up ride in 38F weather it was back to the garage. Started job at 2:30, finished by 6:00. 3.5 hours a bit longish, but I was being very careful. Guess it paid off, no broken parts, or leftovers. :thumbup:
Engine oil change very simple, and straight forward. I prefer the sight glass over the dip stick used on other bikes. I put in about 1350 ml of Suzuki 4 cycle 10W40 and a filter. O rings looked good so I kept the originals in.
Gear oil, could be a lot easier. The CVT plastic shield is silly, but it wouldn't be an issue, if the fill hole was accessible without taking all the covers off. The gear oil drain plug should also have a crush washer, not the brass flat washer which weeps. I used the tried and true RTV to seal it. I wasn't about to take all the covers off again, so I backed out the drain plug by 5 threads, smeared a bead of RTV in the gap and torqued it down. Should do the trick after it cures.
I am happy that the change intervals are so long, and my gear oil came out perfect with no metal flecks detected.
The bike has been flawless. Power continues to improve, and economy is superb at around 60 mpg. The computer hasn't registered above 55 mpg yet. :?
