I have never found a way to over or under rev the engine using any combination of button presses. If the CVT computer disagrees with what you are asking it to do, it will not do it.
The two things I have not tried is turning the key off at highway speeds or pushing down on the center stand at highway speeds. Anyone out there want to test this and let me know?
The 3 things that the CVT computer does mess up in my opinion are:
1: The Burgman 650 exhibits a lot of engine braking in drive mode. The bike does not coast worth a darn and frequently decelerates quicker under closed throttle then I would like for it to. This results in wasted fuel, increased engine wear, and frequently means that I come nearly to a stop without using the brake, ie without brake lights.
The ECVT does need to keep the RPM's up some to avoid clutch disengagement but no where near the 2,800 RPM mark which is what it shoots for in automatic drive mode. If you place the bike in manual mode it will still downshift through the ratios all the way to first but will do so at 1,900 RPM which completely removes the AN650's annoying excessive engine braking as well as saves fuel and reduces engine wear.
In my opinion the automatic drive mode needs to aim for something more like 1,900 RPM under closed throttle condition.
2: The AN650 does reduce the RPM of the engine some when going from light throttle to no throttle (from 3,100 to 2,800) but appears to do this based on input from the throttle sensor registering closed throttle. As soon as the throttle is opened the slightest bit the ECVT immediately varies the ratio to achieve 3,100 RPM again. This results in increased engine braking when only a tiny bit of throttle is applied.
This is an annoying ECVT behavior. The AN650 has considerable power and considerable drive train lash so if you are trying to make a smooth transition from no power to slight power you have to twist the throttle just the perfect amount. To little throttle twist and you will get increased engine braking. To much twist and you will get a jerky transition to power.
I believe this problem should be addressed by damping the ECVT reaction to the application of throttle unless the throttle is applied a considerable amount or applied quickly. Also the ECVT should not vary the ratio at all until the throttle is applied enough that actual power is increased enough to overcome the increased engine drag at increased RPM.
3: The ECVT in drive or power mode does an excellent job of always being at the correct ratio for conditions. However it can be fooled by a rear tire slide or skid. If the rear tire is locked accidentally or intentionally at speed, in a brief period of time the ECVT will vary down to an equivalent ratio of 1st. When the back brake is released the resulting massive engine braking will greatly extend the amount of time the rear wheel is skidding and rev the urine out of the engine as it varies the ECVT ratio back to where it belongs. If this occurs while the back tire is slowing down due to a closed throttle rear tire slide on a slippery surface the resulting increased engine braking may cause a crash. I nearly bit it once on a wet and oily freeway off ramp once due to this.
All of the sensory inputs are already at the ECU to prevent this behavior. If the back wheel stops suddenly it will only take a bit of extra programing of the ECU to know that the bike can not have actually slowed this quickly unless the bike has crashed and damp the response of the ECU in varying the CVT ratio so excess inappropriate engine braking does not occur.
Those are my 2 cents on the ECVT behavior. Now that I have read it, it sounds like I should post the last portion under the section that Suzuki hopefully reads LOL.
