My 07 Exec will not shift out of 1st gear. I found on here that the culprit is likely the center stand switch. I have read Colchicine's Knowledge Base and looked at LeDude's picture and video. However, I don't find anything more than to clean and lube it. Mine seems to be stuck and will not extend.
There appears to be a bolt on each side of the switch. Should I disassemble the switch and see if that will let it extend? If yes, is there anything I should be aware of--such as a spring that will shoot off and never be seen again, etc.
Should I give the switch a little "assistance" in extending--say a little pressure with a very small flat head screwdriver?
Colchicine and LeDude--thanks for all of the valuable information that you have given to us. I really appreciate it.
Any help is appreciated. Thanks, tom k
