Suzuki should not have called those 4 counter rotating 'Reduction' gears the Transmission. True, they do transmit the power from the clutch to the final drive but in the sense of a shifting transmission then NO, they missnamed it. It should just be called 'The Reduction Gears'.
In just about every modern car automatic 'Transaxel' there is, in the same housing case, a transmission that changes the gears (like our CVT). Then the trans output goes to a set of reduction gears. These reduction gears transmit the power to the axle part. They are the same EXACT function as our Burgman's 'Transmission'. ???
