1 - 10 of 10 Posts
2007 400 burg. 4000 miles on scooter, sat for 3 weeks. Turns over but wont fire up. Any tips? I had a fuel additive (star tron) in tank. I'm stumped. Should I use a squirt of starting fluid? Never did this before. And yes there is gas in the tank.
I turn on the ignition, listen for the fuel pump
to 'prime' the system.....you can hear it slow
down & almost stall, then, holding the throttle
slightly open, push the starter button.
If this is the procedure that you use, then the
only suggestion I have, is to hold the throttle
open a bit more.:confused:
Try Adding some Power to the Battery!!
My 97 Shadow 1100 would crank and crank but not fire. If the battery was weak, it seemed that it wouldn't fire the electronic ignition. No kidding.
I wonder if these B400 function similarly. I bought mine used in July 2012 with a new battery, and I keep it on a trickle charger, so far no problems, so I don't have any other insight :violent1: other than are you sure it's getting fuel? Check the spark, pull the plug and ground it, then crank it.
and I wouldn't try starting fluid before making sure that there's spark and air and fuel.
Check the Connections on the Fuel Injector, by tapping the plug!!
Discussion Starter #9
Learned something today. Have to have a good charge in battery. After charging it up it fired right off. Thanks everyone.
Discussion Starter #10
Charged Battery up & fired right off. Lesson learned.
1 - 10 of 10 Posts
