With the house to myself during Easter, I've dragged the scooter into the kitchen/dining room, where I have heat, space and excellent lighting.
What stated out as a cruise control install has extended into bringing mere electrical power up front, now that everything is apart and I have time and space.
And now to the question:
Should I go for complete reversibility, with no cutting of the original wiring harness?
My gut feeling says yes, although it could be much more elegant, without 3 fuses in series as Suzuki designed it.
I have a headlight relay kit with a male plug that plugs into the H4 socket, but I need a third relay, because the left headlight works off its own circuit.
Would you make a wiring diagram to document the modifications? I'm thinking of laminating it and sticking it somewhere hidden under the tupperware, near the relays.
Since it's no big deal to take off the front panel, I think it's OK if the headlight fuses reside beneath. They should only blow if somethings wrong there anyway.
The reason for the desire for improvement is the huge voltage drop in the system from battery to headlight, which is no wonder given the backroads the current takes before arriving at its destination:
From the left headlight -> fuse 2 -> start switch -> fuse 5 -> ignition switch -> main fuse -> battery
From the right headlight -> HI/LO switch -> fuse 1 -> start switch -> fuse 5 -> ignition switch -> main fuse -> battery
