There are three wires to the heated seat wiring harness connector, yellow, green, and blue. Does anyone know what each wire is? I what to connect my heated grips to it and I need a 12v and a ground. The shop manual I have does not show this connector.
You have a '13 service manual? You could use a test light and see what you've got.
I have an old service manual that does not show the heated seat wiring. I have a multi-meter, but I was hoping to to get the info from a wiring diagram. My guess is the newer manuals will show the plug and wiring since it has been on the Exec for some time every where except the US.
Heat switch seat have 2 position, position one driver only, position 2 driver & passenger heat. Perhap that why you have 3 wire.
Discussion Starter · #6 ·
It looks like the green is the 12v in and the other two are to the seat, front and rear. I guess the ground is some where in the ???
I still would like to have someone with a newer service manual tell me if this is correct and where is the ground.
