1 - 4 of 4 Posts
Am adding auxiliary stop,turn,running light kit and need someone to verify which are the
Ground (neg) cable
Hot cable
Any help would be appreciated:cool:
· Premium Member
I don't have a wiring diagram for a 2013 400 but I can tell you the negative will be the black with white stripe wire. The others should be fairly easy to figure out with a test light on the pins in the light sockets.
Craig,
Thanks. I did as you suggested and all connected well.
For some reason, I thought my electronic copy of the Burgman 400 service manual had a wiring diagram. It didn't.
:p
Just curious - which kit did you use? Any pics? Looking at doing this to my 2011 and trying to decide the best option. Thanks!
1 - 4 of 4 Posts
