Why do you want to :?:taly said:Found a salvaged 2011 engine&trans for $900. Will there be any problems swapping these in my 2007?
The bearing in my 2007 failed.Desert Rat said:Why do you want to :?:taly said:Found a salvaged 2011 engine&trans for $900. Will there be any problems swapping these in my 2007?
I can't figure out what you mean.NormanB said:The breaker will probably still have all the 'black boxes' if you are quick.
Yes us with 07's would like some more info please. Mine has 46k+ miles with no engine problem, well except it thinks it's a HD and marks it spot at times. :roll:NormanB said:Are you be able to be more specific?
Which bearing, what mileage, circumstances, history.![]()
The bearing between engine and variator. Started to notice metal shavings in oil, about 10k miles later, failure. 38,000 miles.NormanB said:Are you be able to be more specific?
On the black boxes I meant ECM / Dash and the like.
I gather, by breaker, you meant the one dismantling the scooter; I was confused by the term.NormanB said:Are you be able to be more specific?
