1 - 10 of 10 Posts
Hey guys im trying to tune up my burgman 650 and im changing the sprk plug. I found one spark plug which is on the left side of the bike, however i cannot seem to find the second plug. My intuition tells me its on the right side yet it is impossible to get to as the radiator does not move back on that side like it does on the left. Can someone help me on this...
It is in there but you must fight with the radiator or remove it. I would suggest putting some cardboard over the radiators surface to 1. Protect it from getting bent fins, and 2. Protect your hands from those fins making hamburger of your knuckles.
Believe it or not, the factory tool set has the best tool to get those plugs out.
Make real sure that the coil "CLICKS" into place when done. A very common fault.
Pony up a few more bucks (x2) for NGK Iridium plugs and never change them again.
common fault.
+1 on that. That's what a lot of us do with our Goldwings. Good for 100K and instant starts as soon as the button is hit.
Anyone know which Iridium plug the Burgman 650 takes? I might go ahead and get some for when mine comes due for its first plug change.
Take out the two bolts that attach the radiator hinge to the frame and you can move the whole radiator several inches. You can pull it forward and lower it down without unhooking the hoses once the hinge is loose. That will give you better access but you will still need to come at the plug from the left side.
Looking for the correct size.. Makes sense to upgrade..
What u mean left side? left side when sitting on bike or facing it?
Karim
Have you looked at the 'How To' on Le Dude's site, as referenced in a reply to you above.
If not I suggest you do so now, as it will help you enormously and save you time waiting for specific answers to all the stuff that is well covered in the 'How To'.
Use BUSA search function , so very easy, you will obtain all info you need if use it.
Most these very basic subject been covered many many time before here.
Normally when you say left or right on a bike it is as you are sitting on the bike.
1 - 10 of 10 Posts
