1 - 4 of 4 Posts
I'm Retired
The Burgman Knowledge Base has a chart from the owner's manual showing the different service intervals. Look to the top of the page here. http://burgmanusa.com/bkb/400+b+Maintenance You'll also find tutorials on each maintenance action below that.
Chris
Yes, do the oil change pre-set interval method (ie to set the 3600 mile +\- 300) and it displays the last mileage it was reset at.
If you do not know how then when the ignition on and the main odo mileage displayed (not the trips), press the ADJ button for 2 seconds.
You will now see flashing the last mileage it was set at and then the pre-set interval, standard is 3600 miles and if you want you can adjust this up down in 300 mile increments by the Sel and Adj buttons. to save and exit press the Sel and Adj together for 2 seconds.
Just do it the easy way...every 3000 miles..
3...6...9...12...15...18...21...24...& so on..
2 quarts of oil & a (approx) $8 filter...
cheap assurance for 30 minutes work. :thumbup:
1 - 4 of 4 Posts
