1 - 9 of 9 Posts
Regarding my 2005 AN650 Burgman..... As I research parts and such I keep seeing reference to K4, K5, K6. Can anyone tell me how I would distinguish which "K" model I have?? THANKS!!!
I think it’s a Roman Numeral type of Designation but it’s not Roman cause M is the Roman numeral for 1000. So it’s all Greek to me too.
Reactions: tahoeking
K2 is 2002
K3 is 2003
K5 is 2005
K9 is a dog. Oh 2009
L0 is 2010
L1 is 2011
L8 is 2018
But most Ebay sellers and such are ignorant and just say K3 2008 Burgman.
L1 is the gravitational equilibrium point between the Earth and the Sun.
L2 is the one on the far side of the Earth from the Sun.
L3 is the one on the opposite side of the Sun from the Earth. Used to be theories that there was a planet hiding out there, but there isn't.
L4 and L5 are 60 degrees ahead of and behind Earth in its orbit, respectively.
Only L4 and L5 are stable; asteroids accumulate in those regions.
Lagrange Points
Here's the rub.... As I'm researching pieces/parts at online retailers (not fleabay or amazon) specifically for my 2005 Burg I'm seeing the K-4, K-5 reference for the same part. As in it's either the K-4 piece or the K-5 piece. What the heck is the difference?!?!?!? Was 2005 a mid year parts transition for Suzuki???
On the Step Thru Tunnel just below the Glove Box should be your VIN Plate look for the MFR Date there and go by that. I think ? YMMV
No, most sellers are clueless.
2005 K5 was the major change point on lots of things. It depends on what part too. A K3 Amber turnsignal lenses is the same as a K4 but NOT a K5 up clear.
The K4 is a mid change year. It has the same K3 for most parts but the wiring harness is a big change to the K5 and up. The headlight shut off when you crank the K4 but the K3 does not.
K4 still has only 1-5 on manual mode, K5 up has 1-5 and OD.
K3 and K4 have 4 bolts holding the brake rotors on, K5 up have 5.
K3 and K4 Primary Adapters are the same. K5 and up are the same. But the CVT from a 2018 650 will fit a K3 2003 if you use the K3 Primary Adapter, and the other way too.
Discussion Starter #8
Great info..... THANKS
Lagrange Points
Not a planet, but a Burgman!!!
I KNEW my L3 Burgman 650 something special. It's what's out there on the opposite side of the Sun from the Earth!
1 - 9 of 9 Posts
