1 - 5 of 5 Posts
Am adding some amber LED as side marker lights, found these dead-end connectors, under the dash panels, what is their purpose?
Really would like to find a +12v source for my lights before I start scabbing onto other wires :)
(2008 Burgman 400, a red one :) )
The white one is diagnostics the black could be switched 12v there is one under there for
heated grips but not certain if that's it, don't think it is as I think the heated grip one only
as 2 wires.
Just looked and it's not one of those, if you feel up the back af the left hand looking at it from the front head light
just below the indicator you will feel a loos connector it as 2 wires that's the one you want it's a pig to get at.
It comes off the same connections as the live to the horn so you could piggy back to that it's eraser to get to
and you only need a piggy back spade connector, but you will need a earth, as the horn is only earthed by the button.
That's the bugger the white one right at the bottom below the bigger yellow one
1 - 5 of 5 Posts
