Its located to the right of the oil view glass. Its has an aluminum cover attached wirh two small bolts. Behind the cover is a 9/16 bolt that is 5 to 6 inches long that goes into and thru a very large 1 inch bolt with a hole in it that has splines on it. It almost looks like a gear but it is not a gear. This large 1 inch bolt with a hole in it looks like it is used to make some kind of adjustment. My 9/16 bolt has treads and the threads are gone on the end. I have looked at many diagrams and can not find the 9/16 bolt or the 1 in bolt with a hole in it. It's on my 2006 burgman 650.
I would like to know what this thing does and the part numbers for the 9/16 bolt and the larger 1 in bolt that it goes thru. Also I wold like some help if the replacement bolt doesn't work and I need to rethread or tap it for a new one. Take a look at the pics and help me out.
I found this when i was changing my oil yesterday and I don't want to ride it until I know what this thing is and what it does. Thanks Jim
