1 - 4 of 4 Posts
Never run across plugs like those on my 2007 so must be something added on the newer models.
The plug under the left cover panel is the ECM diagnostics plug. That's where you would install a jumper across a couple pins to display the "F" fault codes. The second is probably the seat heater controller which is not a USA feature so, it is not used.
Ed
1 - 4 of 4 Posts
