1 - 5 of 5 Posts
on the way home i got a vibration thought it might be my front end.check front end when i got home it was okay went to the back tire .Oh Shittttttttttttttttttttttttttttt the lug nuts came loose i know i tightened the dang things cause i torqued them ..makes me wonder did i torque it to the tight ones i swear i read 36 pds per square inch could that be wrong if not why in the world did they come loose if anyone knows swing it my ay ty
Very glad you made it home safely, and the bike in one piece.........at least more or less.
was totally blown away when i took the muffler off.the 3 lug nuts were really loose.2 of them were finger loose :( :( very lucky 1 was not very tight came loose with a slight turn of the wrench .i dunno maybe i didn't tighten them back down dunno..but i seen mitch's video and it said 36 lb-ft so i did that hopefully they won't come loose again .has anyone ever had em come loose
I have never torqued mine down to spec. I use an air impact wrench and go NASCAR on them lug nuts and they have never come loose.
Of course the real danger is stripping them but I do have the air set to only 90 psi not 120 psi to keep that from happening.
You could always use blue locktite to keep them tight. Good Luck Buddy!
yeah i did them again at 36 +maybe and extra 15 lol (praying the Blue Loctite works .LOL..not really funny i think someone forgot to tighten them down last time i had the rear wheel off because i was PO'd when i could 'nt get the bolt out the rear brake caliper hint hint anyways if it dont work this time i'll go to plan B :) thanks Steve
1 - 5 of 5 Posts
