Hercules Raptis TR1 155/70-13 from onlinetires.com. $47 delivered. Mounted it myself on my 07 Burg 400. No real difficulties until one small section of bead refused to seat. Tried generous lube with soapy water, 50 psi inflation/deflation x 6 cycles. No dice. Lubed with spray white lithium grease, upped the psi to just north of 100. Several cycles of inflation/deflation. Let the last inflation sit for about ten minutes, rewarded with an impressive "ping" as it finally seated. Backed off to 40 psi.
Test ride: very impressed. Was expecting some sensation of going over a square edge when cornering, but there was absolutely no such sensation. No extra countersteer effort needed. Cornering is at least as smooth as the MC tire, maybe a bit better.
Will post updates on tire wear.
