Has anyone here changed out there phillips head screw end for the bar weight to a allen head?
If so how did you do it?
Thanks
Steve
Thanks
Steve
whiteknuckler said:Has anyone here changed out there phillips head screw end for the bar weight to a allen head?
Why would you want to change them. If they work loose and you feel you can't get them tight enough with a screwdriver try tapping them with an impact wrench. After doing this mine have never worked loose.
Good thoughtLeDude said:I haven't done it but you can give it a quick try.
The only bell that goes off in my head is whether the allen head screw would be flush with the end of the handle bar weight
and cover the exposed cavity in its entirety.
Personal experience?Dave_J said:Lead fumes and dust WILL cause brain damage.
I ben wrkn wth lead me hole lif. :twisted:MJR said:Personal experience?Dave_J said:Lead fumes and dust WILL cause brain damage.![]()
I have been a Telephone Repair tech for 38 years. Back in the early days all the way up into the 80's Lead was the outer sheath to use as it kept water, bugs and rodents out. The cables had a inner pulp (crude paper) insulation on the pairs. If the sheath seal failed and allowed a drop, yes a drop of water in it would do damage. The water caused a short that heated up and burnt the paper off and then that heaver shorts heat would vaporize the water drop. But the water vapor would just condensate to a new spot and so on, and so on....Dave_J said:I ben wrkn wth lead me hole lif. :twisted:
+1MJR said:Well if you have the factory bar ends you'll need a metric screw and the stock ones are counter sunk. You'll probably want stainless and the Ace Hardware stores around me have a much better selection than you'll find at any Home Depot.
