1 - 7 of 7 Posts
Where is the plate located which shows the VIN? I need it for vehicle licensing
It should be very obvious, it's a metal plate riveted to the tupperware, facing you as you sit on the bike. It's below the center glove box and above the maintenance lid.
In the USA...yes.....in other countries....
maybe not.
Here i Australia its above the radiator ,,,The compliance plate is if you look between the folks and above the radiator.The actual vin number runs down the frame leg on the left of the radiator
I found it. Its stamped into the main fork tube. I was looking for a fitted plate. There might have been one below the glove box but not any more as there are just two small rivet holes in the plastic. My guess is it was removed when it was originally certified here after I imported it. Thanks everyone
1 - 7 of 7 Posts
