On the back I tie down from the bottom shock mounts. On the front I tie down from the fork tubes at the axle.
On your '06-400, there are excellent tie-down rings on the rear frame.cougsfan said:There are no good places to attach a tie down..
I had a friend who tied his Harley at 4 low points on the bike just like you do. It ended up on its side for that very reason. This was on a trailer with a steel deck. A wooden one might have prevented that from happening.Buffalo said:On the back I tie down from the bottom shock mounts. On the front I tie down from the fork tubes at the axle.
Yep - tie it off high!scootntoot1 said:Use the passenger hand grips for the rear tie downs.
Purchase a handlebar tie down strap. It's by far the safest and easiest way.
