Rubble said:
I read that you can trigger the signal if you touch your center or side stand down momentarily while inside the trigger area. I've never had the chance to try it myself.
That's one of those myths that circulates from time to time. Traffic "loops" are capacitive, and a difference of a few inches lower for a small piece of metal won't have any measurable effect. What probably happened is that someone who was impatient tried it, and by coincidence the signal then changed...and an old wive's tale was born.
Even in states that don't specifically say so, running a light after waiting a reasonable length of time for the signal to change shouldn't result in a ticket. Most cops (speaking as a former one myself) use common sense and "officer's discretion" to determine who does and doesn't get one.
If you do get a ticket, go to court and tell the judge/magistrate/adjudicator what happened; he/she should dismiss it.
There are a couple of intersections around here that won't change for me, but most do. One of the ones that won't is on the turn to my work location. I look in my mirrors, and if someone in a car, truck, or bus is coming up behind me I pull forward into the crosswalk and let them pull up to the line and trigger the light. If no one is coming then I wait for a break in on-coming traffic and go for it.
More and more we'll be seeing the buried loop sensors give way to optical sensors. They're cheaper and easier to install and maintain, since they're not buried, and are sensitive enough to react to even small scooters. Of course they can also be tied into photo ticket systems for people who run red lights, but every silver lining has a cloud.
