1 - 9 of 9 Posts
I've been reading a lot about sliders in this forum but is very technical and also people are expecting increased mpg, speed or both depending on the sliders they use. All I want to know is what grams I should get to just continue using my bike and not to increase anything. I read 19g is the recommend but 20g is the stock weight. Which one should be used if all I want is to maintain the bike? Also, in basic terms, what is the purpose of the sliders?
For a 2011 Burgman 400 the stock rollers are 19gm. I put in 20gm sliders and found they are acceptable. The same would probably hold true for 19gm. Or 18gm.
2 days ago I put the OEM rollers back in cause I was wondering if my sliders had maybe flipped. Immediately went back to OEM behavior and I'll be putting the sliders back in tomorrow. Turns out the behavior I was questioning is probably caused by variator wear. My variator has a significant ridge on the outermost diameter of the pulleys. Easily visible by just looking. I'll probably replace the variator at 40K.
I find that I prefer the way the Burg operates with the sliders. It's not a HUGE difference but definitely noticeable.
thanks for your response. when you mentioned you like the way it responds with the sliders, are you referring to the stock ones?
The stock rollers are typically called rollers. The Sliders are the DP parts.
I prefer the DP Sliders.
Just saw CliffyK's update to this thread. You should check it out before embarking on a slider journey. Apparently there's more to using them the pre 2007 scooters.
I installed mine at 13.5k & sold it at 46K+ with mine still in it. That's on a 07 but I would think a 06 or older wouldn't matter.
How long does the OEM sliders last on average men?
The OEM are rollers,not sliders.
I replaced my OEM rollers with each belt replacement...
just a little preventative maintenance....
1 - 9 of 9 Posts
