I realize I have an 03 400 and this could go in that section, but I figured the information may be helpful to others.
Rear specifically; At what pressure should you have your tires at for maximum mileage? My manual says 1-up 29 psi and 2-up 41 psi. Currently, I'm running 34 and eating up another tire.
History; 1st Bridgestone Hoop - 8500 and had a little left (maybe 500), but was old and rock hard so I changed it. 2nd Michelin City Grip - 7100, ran @40/41 psi and wore out the middle - I believe with lower pressure @34/35 or so it would have given another K - loved the grip of that tire (at 41 psi anyway). 3rd Michelin Pilot SC - 3300, ran it at 37/38 in the beginning and lowered it to 32/34 due to wearing quickly - wear didn't really change much after lowering - wear bars are close to being exposed.
I ride mostly, but not always solo and generally like a harder tire (i guess) - the City Grip at 41 psi stuck like no other and felt great.
What should I do to get more mileage out of my rear tire?
BTW, I've already ordered a Hoop to replace the Pilot SC - thought I would go back to original.
Also, I changed the front to a City Grip at 8500 (along with the rear) and it's currently about 40/50% worn - I run it at 28 psi.
Oh, and suspension is set in the middle and I'm 6'1" and about 190 lbs.
