1 - 4 of 4 Posts
I went to check the air pressure on my 400L3 and none of my gauges would register any pressure (yes there is air in the tire). I took an allen wrench and pressed the valve core in and out and .....nothing! No air was released.
What is the easiest remedy?
go to the auto parts store buy a valve core tool and replacement valve cores and remove and replace. I have found if you go to your local automotive tire dealer and release all of the air and refill with nitrogen more constant pressures regardless of outdoor temp or aggressive driving. and no moisture from air compressor
yeah as symtastic said, I also think its the valves core.
1 - 4 of 4 Posts
