1 - 4 of 4 Posts
Would I be correct in presuming that my rear tire is cupping if the leading edge of the pattern is higher than the trailing edge? These are the original Bridgestone Hoops with 64xx miles, running at 30 psi on the rear.
Time for a new tire?
Probably not time for a new tire. Probably normal tire wear. That is the expected wear pattern for rear tires.
1 - 4 of 4 Posts
