Considering the centrifugal forces at work, if less maintenance is the goal (not fuel economy), from a stop, which would result in less wear on the drivetrain of an AN400?
a) twist throttle open wide with confidence and hold it at 5-6k rpm and wait for the speed to catch up
b) gently and incrementally twist the throttle until you're up to the desired speed
Same question, when decelerating to a stop ahead:
c) run the throttle open and suddenly close it fully to let the scooter coast in idle to a stop (braking as required)
d) gently and incrementally reduce throttle so the scooter avoids coasting at idle (braking as required)
