1 - 17 of 17 Posts
Hey Burgies,
What is the purpose of that yellow power button on the 650?
I believe it is also useful to slow down fast too. For instance, I read a thread recently where Pauljo mentioned that he uses it when going through the twisties... So that he can accelerate and decelerate faster.
Joe
No Burger,
There is a separate power button that kicks in extra power, not the one that switches to the manual mode.
roy_ryall said:
The power button on my '03 is grey? Are we talking about the same button?
Roy,
We are talking about the 650's here, the 2004 specifically.
Just for the record, my Power button is grey also. I have a K5.
The yellow is deffo to switch between auto and manual shifting (in a tiptronic sense).
The power button is grey.
So what does the power button do?
Well in 'standard auto' the electronics are set to optimise changing ratios so that a more balanced and economical performance is achieved. I do not recall the exact RPM limit but for arguments sake let us just imagine that the gear ratios change when 3000rpm is achieved on a moderate throttle opening.
So in this scenario you 'engage the power button' the electronics then shift to a different map and will allow the engine to rev up to, say 4,500 before shifting up a ratio - thus sacrificing economy for performance (and thrills). As has been mentioned this will also increase the magnitude of engine braking.
More simply and using a stick shift scenario:
Standard mode - change up early - Power mode - change up later.
Stargazer said:
Isn't the yellow button the "PASS" button? Or is that different on the 650's?
Nice one - that really helps to clarify matters :wink:
Up to the 2005 Exec the pass button is yellow also - they have changed some of the handlebar buttons on the 2005 Exec to accommodate folding mirrors, windscreen operation and the jacuzzi!! :lol:
If it is the yellow button on the front side it is the flash high beam to pass button.
it's used to tighten your butt cheeks. ;)
You'll need to clarify the question.
There are two yellow buttons; the "Pass" button in front of the left switch cluster, and the "D->M" (Drive or Manual) button on the lower/rear of the left switch cluster.
Then there is the "Power" button, which is grey and located in the middle/rear of the left cluster.
Unless they've changed colors on me there isn't a yellow "power" button.
So, which one are you asking about?
Discussion Starter #15
Ok Brian,
I must be wrong then, but whatever color it is, lol, what does it do?
It changes the automatic gear ratios so that the transmission is in more of a 'sport' mode. NormanB put it pretty concisely a few posts up.
Discussion Starter #17
oK i GOT IT NOW.
aND YES THE BUTTON IS GRAY, oops!
1 - 17 of 17 Posts
