I was unable to ride my new leftover 2011 B650 before purchasing... didn't take long to determine that this was the harshes riding motorcycle that I have had in 40 some years of riding... I was going to have to do something or dump it.. I was cringing at every bump.. looked at the forum and found everything I needed to make it ride better..
Front.. Racetech Emulators.. after some trial and errors I ended up with stock springs and spacer( uncut). Emulator 64lb spring 1/2 turn. Damper 4 holes enlarged to 3/8".. 15wt Maxima fork oil at 5.5"... what a difference this made.. I can feel the forks working but now none of the shock gets to the handlebar and into my arms...
Rear.. Modified a set of Honda air shocks that I found on eBay.. running with no air.. tried air on the inital install and found it better without...had a seal leaking and after replacing the seals I removed the air lines.. lots better that stock..
About $260 total and a lot of old man time...having to do everything twice...
Thanks again for all the post on suspensions.. read them all numerous times while doing this...
Hamie
Hamie
