I recenly augmented my Chineese 257cc scooter with an aux LED light and was happy with the results. I was looking for low power draw, quality, and easy of mounting. I believe I have found all three.
The lights were sourced from a USA vendor, Super Bright LED, and I have delt with them faborably before. Quick and honest.
Since this is a Burgman site, I decided to pass along my experiences with two days of riding using the new LED on my 2011 400.
Some specs.
Lights rated at 750 lumin.
Power draw .8 A 9V-60V DC
They come with a nice pig tail two wire harnes, with a quick disconnect, and all mounting hardware.
I was looking for more curb illumination, and enhanced fill in for my low beam riding. The beam is rated at 20 degree pattern, and that seems accurate.
Light colur output is good maybe a little high, but not like some kid poser or those BMW lights. The box said 6500K but I think they are closer to 6000k. I looked on the CREE web site and that seems more true to the light I am seeing. Sorry, I have no means to measure the wave length.
I came up with a easy method to power the light using the plug to the small 194 "like" bulb above the main beams. I didn't want to penetrage the OEM wiring, and found sacrificing the light output of one of these bulbs a good trade off. The plug also accepts standard spade male connectors, a big plus for super easy installation, no wire cutting and secure fit.
I soldered the mail spade plugs onto the pig tail of the LED. With the 194 "like" buld probably being rated at 5W, I didn't think the LED would pose a problem for the existing wiring. I decided against a switch since the electrical amperage is so low, cant see why I would ride without the light.
I fashioned a mount from aluminum flat bar stock drilling a mount hole in the fron for the light and three 1/8 inch holes in a : - type pattern for some pop rivets I would used to secure it to the lower chin of the Burgs front fairing.
I found the mount a little springy due to the plastic in the fairing, so I wedged a wine bottle cork between the mount and the bike housing to dampen the spring motion. Seemed to work for now, since I am limiting my garage time until the weather warms a little.
Well Here are some pics below.
Some specs.
