1 - 5 of 5 Posts
Anyone interested in making templates for the three front storage compartments...here is an easy,quick way.
Measure the width of the compartment. Now take a sheet of bond, printer, paper and some sissors. Cut the paper a couple inches wider than the storage compartment and long enough to fit the compartments depth.
Insert the paper into the selected compartment lining up one stright
side with the stright side of the compartment. Now using your fingers and fingernails run them around the edges till the paper becomes shaped to the compartment. On the front bend the paper down to create a front line.
Remove the paper and carefully cut it along the slight groves you created. Reinstall the paper and make any small corrections needed.
One template works on both upper compartments. You will need a left and right for the lower one.
Chuck
Oh - I thought you were going to provide the dimensions of the template! :shock:
INfo
Norm...giving you the dimensions would be difficult as there are three totally different shapes involved each having varied dimensions, curves etc. The way I described to you only takes a few minutes then can be outlined on the material you choose to use, cut out and installed.
Suggestion: instead of paper, use heavy aluminium foil; it'll hold the shape/show the creases better.
1 - 5 of 5 Posts
