I have a stupid problem and probably need a stupid answer, but I am stupified at it all. I have a 400 seat I need to work on and the backrest has to come out. However, the screws are still in the pipe and it wont slide out. The problem is that the screw spins all day in both directions, but will not back out. I have used a handheld screwdriver and an electric screwdriver, but it will not fall out. The + for the screw tip is not stripped, just the threads. I tried a drill bit to force it out, but that does not work. It basically renders the seat useless.
I have tried needle nose pliers, but they can not get a good grip especially since it's protected by the hole above it.
What do I do?
What do I do?
