brake levers are tight and are not smooth like it used to be.does anyone else have this problem?
A aaron frazier · Registered Joined Jun 8, 2013 · 2 Posts Discussion Starter · #1 · Jun 29, 2013 Only show this user brake levers are tight and are not smooth like it used to be.does anyone else have this problem?
NormanB · Premium Member Joined Apr 7, 2004 · 10,292 Posts #2 · Jun 29, 2013 Only show this user I think this is the first report of this. Have you dropped the bike? Well there is not too much to a brake lever take the pivot out, give it a clean and lube.
bikerdoc · Registered Joined Sep 16, 2012 · 426 Posts #3 · Jun 29, 2013 (Edited) Only show this user No... on neither my AN650K3 nor AN650K7 Suggest ...lubricant...
Buffalo · Premium Member Joined Aug 17, 2005 · 13,531 Posts #4 · Jun 29, 2013 Only show this user Lubing the brake levers is one of the maintenance items you are suppose to do. I use a little shot of white lithium grease from a spray can on mine.
A aaron frazier · Registered Joined Jun 8, 2013 · 2 Posts Discussion Starter · #5 · Jun 30, 2013 Only show this user thanks
