Hi All
New to the forum and looking for some help
09 650 ABS Burgman 3000 miles
My rear brake has started sticking and has even discolored the disc
Things I have checked so far
1 Removed parking brake adjuster (brake still seized
2 Removed caliper (very hard as pads very tight on disc)
3 Remover slider (free and coated in red grease)
4 Removed pad pin's (free and coated in silver grease)
5 Pad's now worn but seated correctly
6 Hand brake piston very free screws in no problem
7 Fluid piston can push in with one finger and turn in seals
I am at a loss fitted new pads (after screwing piston back in and fitted pad in slot on piston as wsm 9-75)
As soon as you put the brake on hard you really struggle to turn the wheel (this is still with the hand brake adjuster completly de adjusted)
If you look from underneath you can see that the handbrake piston is not returning,it is just screwing out and staying there?
Has anyone any ideas could the valve in the caliper be faulty 9-88 wsm
Thanks in advance for ANY help
