Sorry, at 75 I'm too brain dead to read the 444 plus member responses for stems and trailering. Two years and 1000 miles ago I bought my 08 executive. The original owner tied it down on my uhaul trailer rental and I made it home 80 miles without any problems. I had new tires installed at a dealership and they did not recommend anything about stems. I hadn't owned a motorcycle in 12 years and I did not remember about angled stems. I went to my shed a couple of hours ago and noticed that I had a rear flat tire. I had just driven it 2 days ago and thank God it didn't happen while I was doing 75mph. I have been lucky and not had a flat in over 40 years on a car and never on a motorcycle. I proceeded to air it up but it would not hold the air. I first thought the valve was blown out of the stem but I think it is the stem. I've done several maintenance jobs on my scoot but I can't remove my rear tire. It's above my pay grade. I am going to call the dealership on Tuesday. First, will they have the stems in stock, that you members recommend (which are), or do I need to order them online. Next, I am going to call AAA, which I have never used for car or bike, to take it to the dealership. This is where I need you smart guys to tell me how to tell the driver to Exactly tie her down....Thanks I really appreciate all of your imput. Ready2ride....keep the rubber down.
Tie Downs:
What
@rjs987 said above should help you out. I don't have any experience in this area, but what he says sounds good to me (based on years of reading posts).
Valve Stems:
Also over those many years, I have replaced stock valve stems mostly with low-profile, near-right-angle stems, such as these, from two reputable outfits:
Right angle replacement motorcycle valve stems for easier inflation. Balanced, easy to install and fits most Japanese, European and USA motorcycles.
store.soundrider.com
Those angled valve stems make adding air much easier. Point them left or right, in a way that makes adding air easier for you; in my case, I like the one in front on the Big Burgers pointing to the right (given that the bike will lean over toward the left, if on the sidestand), and the one in back pointing to the left, because I find that there's more room to get in over there out back (although some folks disagree).
It's possible that a dealer will have these low-profile aluminum valve stems in stock. I
prefer the low-profile versions over, say, this kind (although they will do in a pinch):
Buy Show Chrome Accessories (5-802) 90 Degree Nickel Valve Stem: Motorcycle - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
I would stay
away from anything that has a bunch of rubber, such as these:
Buy OTAUPRS 4 Pieces PVR70 Snap-in Tubeless Motorcycle Tire Valve Stems 90 Degree Fits 0.453 Inch Rim Holes Nickel Finish: Stems - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
By the way, if you go on Amazon and enter, say,
90 degree valve stem in its search box, you will see a boatload of the possibilities.
And keep in mind that something like this ...
Buy Mellbree 2-Pack Tire Valve Extension, 90 Degree Schrader Tire Valve Stem Extension Brass Adaptor Compatible for Passenger Cars, Stroller, Bicycles, Motorcycles, Trailers, RV and Recreational Vehicles: Tire Valve Tools - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
... is for
temporary use only, i.e., when adding air,
not for keeping on a bike while riding.
Another note: the Big Burgers have the common 11.3mm rim-hole size, so that's a plus.
Final note: on my last two bikes, going back half a dozen years now, I've added the T-Valves from FOBO (which fit both the common rim-hole sizes):
This is bulkier than the low-profile valves stems I suggested above, but has two advantages:
- It provides enough room to add an external TPMS sensor (such as the ones from FOBO, which I now use, or from other manufacturers); the low-profile ones probably do not offer enough room).
- You can add or subtract air with disturbing or otherwise messing with a TPMS sensor.
I'm 74 now, and about a decade ago I decided I was getting too old to get down on the ground to check or add air (which -- getting down on the ground -- was a requirement with the bagger/dresser I had, with hard saddlebags obscuring the back wheel). So I started adding TPMS sensors to my bikes. I can do a pre-ride check standing up, no tools required, which I really like.
I bought my T-Valves directly from FOBO, and the shipping was quick enough. You can also get these at WingStuff (with whom I've also done business a time or two over the years):
Check out the deal on T-Valve Optional Accessory for FOBO 2 TPMS at WingStuff.com
wingstuff.com
I doubt any dealership stocks these, though.
You can always go with whatever the dealer has, for now, with your repaired or new tire, and go with a more preferred solution the next time you need tires.
Good luck.
