Ok - I have run into a problem trying to tighten my steer stem head nut and was hoping someone could provide an answer to my problem. Currently my Burgman only requires a force of 50-100 grams of force to cause movement (with front wheel elevated off ground.). I purchased an inexpensive tubular spring gauge and wanted to tighten steering stem nut to require more resistance to within specs (200-500 grams) of force. I was following the adjustment procedure listed here.
http://burgmanusa.com/gallery/Jims-Gall ... 7.jpg.html
I removed the dash and handlebar covers today. Then I removed the 4 bolts that fasten the handlebar to the triple tree and have the handlebar secured temporarily with a nylon strap to keep stress off of the brake lines. Now if I could just loosen the ‘steering stem head nut’. I thought I read where this was a 20mm nut – only to discover it is much larger than that. Can someone tell me what size nut / socket this is?
[attachment=0:1cbjxmc5]IMG_1592.JPG[/attachment:1cbjxmc5]
I also read that I need that you need to loosen the two lower and upper bolts that lock the forks. Just curious as to what would happen if you did not loosen those bolts ?
Thanks in advance
Thanks in advance
