1 - 3 of 3 Posts
When I installed handlebar risers I went with thin braided custom lines from Spiegler Performance Parts. The main reason I opted for the Spiegler lines was I couldn't find a generic replacement line longer than the stock ones with the correct ends. Our banjo end has a double bend in it. Most over the counter ones only come with one bend or straight. But ultimately it was the other end that connects directly to the hard lines that I couldn't source. I ended up buying these custom lines from a local dealer that was willing to allow me to return them if they didn't fit. If you buy direct from the website, there is a no return policy. All in all, I'm very happy with them. They look better than the stock and because the relationship of the banjo to the line is adjustable, you can get them to lay anyway you want. They're braided, not rubber!
For those interested here are the order numbers I used for each line:
047-610-032
047-610-022
The "047" being the hard line end, the "610" being the length in mm, and the "032/022" being the left and right banjo ends.
1 - 3 of 3 Posts
