1 - 2 of 2 Posts
2003 650 Bergman at times when starting the engine it just clicks continue to push to starter and 2003 650 Bergman at times when starting the engine it just clicks continue to push to starter and eventually will start . The next time it may start on first try, all lights are bright so the battery is charged. Any suggestions for the problem could it be the starter solenoid relay .
You've posted in the wrong section. This one is for technical issues with the board. Should have posted in the 650 section.
In answer to your question. Yes it could. It could also be a loose connection somewhere or a problem with the starter button or a problem with one of the interlocks on the sidestand or brake levers.
1 - 2 of 2 Posts
