1 - 5 of 5 Posts
I just bought a 2007 Suzuki Burman 400 some time when I hit the starter switch I hear a click but the starter does not turn I just rode about 10 miles with a few stops and two times it did this I hit the starter switch again and it fires right up. One time at a stop sign it shut off again I hit the starter switch and it fired right up seems to run fine but there is something going on any help would be greatly appreciated
Could be a flat spot on starter, or electrical voltage drop...It sounds like the solenoid is kicking in...Check battery voltage and terminals also.
First thing that comes to mind is to make sure your battery terminals are clean and tight.
What Doug said. Mine did that and it was a loose battery connector that kept popping out. Those darned little nuts inside the post are a PITA to get right the 1st half dozen times.
1 - 5 of 5 Posts
