I have a 2008 Burgman 400 k8 with no issues at the moment, but want to change out the lead acid battery and make a home made lifep04 (lithium iron phospate) in the medium term future. I have built rectifier/voltage regulators in the past with success so this ought to be easier, or at least not harder to do.
The issue is I need to know the amperage draw from the starter motor while it is cranking so I can choose appropriate amperage battery cells. A half hour of searching this site and the Internet has given me no joy at this point.
What I have found out is a replacement starter motor is rated at 1.5 kilowatts. That's about 125 amps at 12 volts. Wow! I suspect that is way more than the scooter actually uses, but how much is needed? Does anyone know? Right now the cell candidates are:
batteryhookup.com
batteryhookup.com
The Headway cells will certainly do the job with a 200 amp discharge capacity, but if the amp draw is signficantly less than 125 amps I can make a much more compact parallel battery pack with the a123 cells with a 30 amp draw. The price for capacity per dollar is close enough I am not concerned with the price difference.
USED HEADWAY 38120 HP 3.2V 8AH LIFEPO4 BATTERY - $195/kWh
PRICE DROP AGAIN! NOW JUST $5/CELL FOR TRUE LIFEPO4 POWER CELLS! BACK WHEN THESE CELLS WERE $12 EACH USED AND THE BEST VALUE FOR CAR AUDIO, WE CONTINUED TO PUSH HARD TO SAVE YOU MONEY AND MAKE THESE CELLS THE BEST OVERALL VALUE ON THE MARKET FOR CAR AUDIO AND NOW EVEN FOR SOLAR STORAGE. THESE...
A123 18650 APR18650M1B 1100mah Lifepo4 - $199/kWh
Price is for 1 cell. If you order 100 we will ship it in the original box. Otherwise we will ship them in custom packaging. Just $0.72/cell for excellent power cells for smaller projects. Here are brand new in the box A123 APR18650M1B Lifepo4 batteries. Our guess is A123 makes these cells for...
