1 - 8 of 8 Posts
Hi Have found the solution to being able to close the glove box after fitting a USB into the 12v power outlet. Simply fit a mini USB adapter into the power socket, then you put in a USB connecter which is a right or left angle to suit. to avoid confusion have found them advertised in china for about 3 dollars a pair including postage.
White Burgman 650 standard
Here you go
Amazon.com: Scosche powerPLUG Low-Profile USB Car Charger for iPad and iPhone 5 (USBC2M): Computers & Accessories
There are lots out there
Griffin is very good quality - two usb out and this is a deal if you are buying something else on Amazon.
Amazon.com: Griffin Powerjolt Dual Universal USB Micro Colors May Vary: MP3 Players & Accessories
I use one of these as well
the cable is flat and you can close the door easily and adjust the length
This works well for me - can go on either bar...
easy on and off
I got the cigarrete adapter for the gerbing gear and realized later on this will prevent me to close the lid. so i had to use the battery harness.
after awhile i found this:
on ebay 2-Way Double Plug
this will allow you to plug anything.
Great idea! I like the thin, flat cord. I've been using the Garmin cord and having to shut the glove box quite uncomfortably. I even cut a small opening just for it. This will fit much better.
1 - 8 of 8 Posts
