1 - 3 of 3 Posts
Anyone else have a small thin film of oil underneith collecting dirt. 2100 miles, '05, seems should be clean as a whistle under there.
Geo.
I agree, it should be clean, you could try tightening up the drain plug --just a little--
If that does not work I would take it out and check for a cross threads and make sure the washer is still good. Also check and see if you can locate were it is coming from, may not be the drain plug.
If none of that works take it to a dealer !
Wipe it clean first. Real clean, maybe even use a solvent. Then ride then check for your leak. It could be the residue from the last oil change. Yes it should be real clean underneath there.
1 - 3 of 3 Posts
