1 - 9 of 9 Posts
So, just took a 400+ mile trip and was going up some pretty steep mountains and hills. Somehow, I still got 72mpg. I'm thinking about it, is this because when going up a hill it puts it in a lower "gear"? I could be completely off, but thought I would check.
It seems that a lot of the people who get the really high mpg's on their 400's come from States with liberal marijuana laws. Wonder if there is a correlation. Might be worth telling the weed doctor about my depression from getting only 53-55.
A CVT transmission is operating 90+% of the time at optimum RPM thus the mpg does not vary as much as it does with a manual transmission.
Were you riding at high altitudes. The electronic fuel injection leans the mixture down at higher altitudes which gives better mileage. When I was riding my 650 up in the high mountains of Colorado I was getting 60+ mpg which is the highest mileage I've ever gotten on it. Never had my 400 at altitudes like that but I suspect it would react the same way.
When riding into higher altitudes and fueling up - keep in mind that the octane rates are different! They are usually a couple of points lower because of the higher elevation. Not a problem while you ride there but once you go back down the octane may then be too low and detonation occur. I live in the Rocky Mountain octane zone so I use regular here but if I were going to travel into a lower elevation I would buy a grade higher just to be safe.
I don't know what you call a mountain in AZ, but here in VA and WVa my 400 gets worse mpg when riding in the mountains. Everyone I know that had a scooter or car with a CVT sold them because of the performance in the mountains. I don't believe you got 72mpg in the mountains unless you cut the engine off and drifted down the mountain.
The highest peaks in VA and WVa are in the range of 6,000 feet. The highest peaks in AZ are in the range of 12,000 feet.
Yep, those are mountains in AZ. Now I really don't believe that he got 72mpg. I regularly get between 65-70mpg with my 05 Burgman 400 travelling up and down the interstate. Rideing the interstate, even a tail wind or head wind has an effect, mountains change that even more.
Discussion Starter #9
I don't know what to say. I checked the math 3 or 4 times. It came out to 72. I was pretty shocked myself. I just kept the cruise control on where it didn't break 6,xxx rpm. Maybe that was it?
1 - 9 of 9 Posts
