If anyone can help me out with this I'd be much obliged. I have Skype (scottp8181)
I am not sure about warranty issues if you do. You are talking about the polystyrene hard foam, not the soft padding foam? Yes that has been done before. Within reason you can shape a helmets foam to fit. Most guys I know that have done it give a ratts rump about warranty's. :thumbup:Scotty1981 said:Is it safe to dremel into the foam a little around the ears so I can set the speakers in more deeply?
The "Within reason" part means that you will not be hogging out lots of foam. You need WHAT, about 1/8 to 1/4 inch max? Just make sure that the speakers are set "SUB-SURFACE" to the foam so they do not cause injury in an impact. Funny, my old EXO400 had pockets for speakers.Dave_J said:I am not sure about warranty issues if you do. You are talking about the polystyrene hard foam, not the soft padding foam? Yes that has been done before. Within reason you can shape a helmets foam to fit. Most guys I know that have done it give a ratts rump about warranty's. :thumbup:Scotty1981 said:Is it safe to dremel into the foam a little around the ears so I can set the speakers in more deeply?
