1 - 8 of 8 Posts
Hi,
I'm unable to open the seat in my 2007 Burgman 650. I red the post which advise to push hard on the seat and turn the key without any results.
Would removing the central frame cover above the tail light (see link below) allow me to unlock the seat if the cable is broken? If not, what is the right procedure? What panels do I need to remove?
Center frame cover removal (Step 3)
http://burgmanusa.com/forums/32-how/22486-starter-removal-650-body-panels-facilitate.html
Thank you
1st. try pounding on the seat when while your turning the key. Sometimes if there's too much stuff under the seat, the seat won't open.
Next, grab the cable on the right-hand side of the bike under the service cover with a pair of pliers and yank forward. You have to grab hard enough to grip the cable inside the sheath.
If that doesn't work, you may be looking at removing some tupperware. There are other posts here about unlocking the trunk without the key. Do a search.
Regards
Scott Fraser
try pounding on the seat when while your turning the key --> won't work
grabbing and yanking the cable forward the bike under the service cover --> won't work
The central frame cover above the tail light does not come loose after removing the screws. Looks like is stuck in the middle under the backseat.
What tupperware do I need to remove to be able to unlock the seat?
Also re
Mine was stuck too.. for a while.. Finally I sat on the seat..and turned the key and I heard the pop that it was now open..
Got. Pounding on the seat while turning the key did the trick. I just lubed it and it works fine now.
Mechanical eh? Who would have guessed.
Thanks all for the help.
Doug
1 - 8 of 8 Posts
