Well it's been raining like forever here, so with 2,600 miles on the burgy it was a good time to really go over the scoot hope I'm not too windy.
Seat
Saturday I was in the garage for 11 hrs. working on all my vehicles. I decided to work on my seat (again). I installed a few layers of soft open cell foam over my gell pads, the gel pads work great for jarring bumps and vibration, but they are not soft. I installed about 3/4" thickover the whole seat and doubled it up on the front 1/2 on the driver and passinger and on the butt stop and passinger backrest. Test sitting seems to be a lot softer.If it ever stops raining, we will see how much better it works. I added pictures to my seat mods. http://burgmanusa.com/gallery/Seat-Mods?page=1
Front End
Sunday Morning I started on the front end wich still seemed to wobble a bit at high speed (70). Increasing the rear suspension helps but it still wasn't right. I found the steering head was about 1/4 turn too loose, snugged that, but there was still some left. I was going to take the front wheel off to chechk that out. Removed the pinch bolt then startetd on the axle. Well guess what It's supposed to be at 47 ft. lbs. and it was hand tight. I pulled the axle out and tried to drop the wheel (I did not take off the calipers because the bolts were too tight) I couldnt get it passed the fender. So checked out the the bearings with it in there, they seemed OK, but a little dry, so I added some bearing grease befroe re assembly. Trying to set the wheel back I couldn't because of the Brake pad clearance, so I removed the pads. Well that was really easy, 1 cover screw and 1 allen bolt, then they just slide down. Plenty of room to reinstall the wheel, Torqued the front axle and pinch bolt. Reinstalled the brake pads, again real easy. No more slop and the wheel turns free.
Changing the front brake pads should take no more than 1/2 hr. when they need replacing (good news).
Bottom Line, Check the front axle . Some of the instability some members are talking about may be related to this
Seat
Front End
